My girlfriend's phone has never been able to send or receive pictures via MMS. I googled a lot and found the APN settings. I tried multiple reboots, airplaine and all other other suggestions. No success.. She's about to leave Fizz...
Only difference between her and me is the phone. I have a Galaxy S8 and she has a Nexus 6.
Fizz APN settings are:
APN: mobile.bm
MMSC: http://mms.mobile.bm
MMS proxy: mmsproxy.mobile.bm
MMS port: 80
APN type: default,mms,supl
Make sure that Data saver in Settings, Connections, Data usage is turn off.
That was preventing me from receiving MMS.
I forgot to mention I also did this. Thanks for the recommendation :)
Some users have reported they had to delete the default APN profile settings and create a brand new on from scratch.
Then powerboot the phone.
Also, try it with WiFi connected to internet to see if it's working, just to make sure it's not Fizz network related only.
Cheers :))
I tried with and without wifi.. After reboot and after airplaine mode.. I'm next on queue with Fizz support to try to sort it out..
Update : I did chat with Fizz support. They have no clue.. It went to another team.. I also pointed out I reffered my girlfriend and it doesn't show anywhere.. If they can't AT LEAST give us the referral bonus, we're out of here.
Si une réponse répond à votre question, veuillez cliquer sur le bouton vert sous la bonne réponse. Ça va permettre de fermer la discussion en indiquant que vous avez trouvé réponse à votre question.
Exactement comme celui-ci:
PS: Vous pouvez aussi donner des kudos (similaire à un "J'aime") en cliquant sur le coeur.
