I opted for the Quebec + Canada coverage, I’m travelling to Toronto next week, will it work from there or only while I’m physically in Quebec?
Yes, you can just keep in mind that it is against Fizz's policy to use roaming more than 50% of the time or for 3 consecutive billing cycles.
It will work in Toronto if you have a number that fizz covers and you also needed to have gotten your sim card that they only ship to the Quebec and Ottawa region.
It will works. No problem as you have Canada coverage.
I was in the GTA last weekend and it worked fine for me. Don't forget to enable data roaming in your phone settings though.
