How long does the number porting takes from Fido to fizz?
Hi Zibo,
I can see that you had one of our agents by chat and he did the necessary for you.
The situation will be solved as soon as possible and we'll keep you updated.
We're here for you.
Have a nice day.
Corina.6
It took mine about one hour to get it fully working. But. had to force my iPhone to reload the carrier settings, since it wasn't doing it on it's own. I had to go to settings->general->about and then I got a pop up informing that the carriers settings had changed.7
1, 2 hours7
Hi! Mine took less than 30 minutes. I didn't even had to restart my phone after I inserted the sim card. All features are working perfectly.
I have a Pixel XL7 -
you need to reboot your phone..i did the switch from fido to fizz yesteday7
please let me know if your sms work cuz mine dont work at all. ive got an Iphone7
Thanks a lot guys for the help. My SMS doesn't work. Every time I make an outgoing call, I can see the phone is indicating "conditional Call Forwarding Active". My understanding is that means the switch is not done yet.7
BTW, I have rebooted the phone a few times, then switched to another Galaxy S7. Still same symptom.7
Around 1 hour, I need to restart my phone.7
I didn't need to reboot my phone (Galaxy S8). It worked instantly (well, I tried after 1 minute to be exact).7
Can not receive phone calls for 2 days now!
How can I get ANY support from FIZZ?7 -
Try to write to them on Facebook messenger or chat bubble , make sure your pop up blocker is desactivated. Good luck7
Thanks for getting back to me. Yes I have chatted with a customer service and was told that I will get update via email. But not progress yet. And my data doesn't work either. Can Fizz support at least help me to get the data going?7
It's been 3 days of no being able to receive any phone calls or text! I have contacted Fido and they told me they didn't see the porting request. But my old Fido sim card stopped working, too. So please help me!7
Hey Zibo,
Any updates on your end? Did, you get that data working? Everything looks good on your account from on my end....please update us7 -
For me it took less than couple of minutes. I thnik it is recommended to use IMEI instead of account number while completing migration process
Thanks8 -
OP am in the same boat as you. I did however get my data working by following the steps in the following video >> https://youtu.be/qbfOqL6Li3M3
